Billet subframes... do you care if the lines match the engine?
Webike Japan
Příspěvek od Webike Japan » úte črc 14, 2026 08:06:54
I was checking out the new Trick Star billet subframe for the Z900RS. Because it's fully machined from a solid block rather than using welded tubing, they were able to design the structural cutouts to perfectly parallel the fin lines on the cylinder head.
It’s an incredibly clever touch that unifies the whole engine area, but it got me wondering about how we shop for structural bracing.
When you’re adding heavy bolt-on parts like subframes to a naked bike, how much do you care about these hyper-specific design alignments? Do you actively look for aftermarket parts that mirror the factory engine lines, or do you just bolt on whatever chunk of metal stiffens up the chassis and looks tough?
https://japan.webike.net/products/26570714.html
Re: Billet subframes... do you care if the lines match the engine?
Příspěvek od KankX » úte črc 14, 2026 09:56:12
nechávám jak je z výroby... na to naše hrkání je to OK
Webike Japan
Příspěvek od Webike Japan » stř črc 15, 2026 05:58:30
KankX píše: ↑úte črc 14, 2026 09:56:12 nechávám jak je z výroby... na to naše hrkání je to OK
To je pravda. Když sériový díl funguje dobře, nemá moc smysl ho měnit jen kvůli vzhledu.
